Carburetor rubs hood
Discussion in 'General Maverick/Comet' started by Wutend, Sep 4, 2023.
  1. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    I recently replaced my carburetor gasket on my 250. Everything is stock as far as I know. But now the carb and air cleaner hit the hood. You can visibly see a difference when you shut the hood. I never had this problem before. The new gasket wasn't much thicker than the old one.
  2. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
  3. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    Here's the gasket and how it looks. But pics of how it looks with the hood shut you can't really tell
  4. TeeEl
    TeeEl Senior Member
    Colorado
    How much thicker is the new gasket compared to the original gasket?
    Mavericks have a substantial amount of hood clearance, so something is not right...
  5. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    It's not much thicker maybe a few millimeters. Doesn't make much sense to me
  6. Powerband
    Powerband Member
    NY's \H/
    The Maverick hood is the lowest of the Falcon Six based cars. The 250 is basically a 'stroked' 200 with a block deck height almost 2" taller than the 200 - needing the unique Carter RBS carb with the squat profile and low fuel bowl. Later (75 up ?) used the YF with a unique but different Air Cleaner.
    If carb or AC have been switched at any point, there may be interference with the low hood line.
    hav e fun
    RBS
    YF'as
  7. TeeEl
    TeeEl Senior Member
    Colorado
    I assume the I-6 is taller than the V-8, because I'm running a Weiand stealth high-rise intake with a half-inch carb spacer, Holley 4150 series carb, and a full-size air cleaner without any clearance problems. In any case, the O.P. says he only replaced the carb gasket...
