cd player probs as always....
Discussion in 'Audio' started by TURBOEDSOHC87, Feb 1, 2007.
  1. TURBOEDSOHC87
    TURBOEDSOHC87 Member
    lancaster,pa
    75 comet 5.0
    :huh: ok so I have a 75 Comet with a 302, i just installed a new cd player in it but when i was removing the old one (a ****ty boat am/fm radio)who ever had the car before screwed up alot of wireing. I have 1 dash speaker i know that, wire color is black and black striped white, ok but the other is a plug it has 4 wires going on and 2 coming out,I believe its a blue with a red strip, and the other is black. Well it seams black is a 12v key on well i was tryign to fix all the wiring, everything works fine but just my gauges dont light up, like the gauges work but no light comes on..? whats the deal what happened and theres nothing undone and i cant see anything... help.. the cd player works great but like i said not dash lights?... werid
  2. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    There's a wire down there that goes to the radio, it powers up the radio display backlights when you turn your headlights on.
    Probably blew a fuse when you were messing around with stuff. Check your fuses (I don't envy you for having to do that! ;) )
  3. TURBOEDSOHC87
    lancaster,pa
    75 comet 5.0
    grr
    grr i checked and replaced all the fuses, and cleaned the fus box now is the only one fuse box or 2 ?:(
  4. Jamie Miles
    There is only one fuse box. Every dash light problem I have had has had to do with the head light switch. Before doing anything, make sure the head light switch is rotated to the left, just before it clicks. If stil no lights, rotate it slowly back and forth and see if the dash lights flicker on and off. Did the lights work before swapping the radio?
  5. blue76maverick
    blue76maverick Member
    east tenn. GO VOLS!!
    76 2 door
    also, make sure you have a ground.
  6. TURBOEDSOHC87
    lancaster,pa
    75 comet 5.0
    ok
    yeah they worked fine but some butt head had all the wireing choppped up if you read my first post i gave the wire colors and i didnt get a responce but theres a blue and red striped wire not doing anytihng and theres nothing undone like i cant see any other wires undone you know everything is hooked up everything works the headlights everything just not the backlight to the gauges and speedo.. so im pretty much lost people keep replying about things i didnt say:( ill try and get you a pic soon ok
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    :chillpill They are trying to help.
    Go to www.maverickcomet.com and go to the Features section and select Wiring Diagrams. This should help you trace what the wires in question are.
  8. 19BlacK77
    19BlacK77 Member
    Sounds like the plug on the back of your gauge cluster isnt getting good contact with the printed circuit that runs all the lights in the cluster. (I just had that problem on my 77) The gauge cluster may be dry rotted causing it to do that. :huh: Just a suggestion, I could be wrong.
  9. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    Are you sure the light bulbs in the instrument cluster aren't all burnt out? The blue wire with the red stripe is the backlight circuit. Anything connected to that circuit will get powered up when the headlights/parking lights are on, and will get dimmed when you turn the headlight switch...
  10. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    My guess is the same as one of the above. I bet it is in the headlight switch. When I rotate my headlight switch right and left to dim the dash lights there are a couple dead spots that cause the dash light to go completly out.
  11. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    Try spraying some contact cleaner in the light switch and rotate it a couple of times. I think your having the same problem I had (a dirty switch). Just my two cents! Good Luck
