coil problems
Discussion in 'Other Automotive Tech & Talk' started by mean_maverick, Mar 23, 2009.
  1. mean_maverick
    i have 12v going into the coil and 12v coming out the other terminal on the coil but cant get it to fire. replaced the coil with two others i have..... am i missing something??? :16suspect
  2. Jamie Miles
    If you've tried two other coils, sounds to me like some other part of the ignition system. What ignition system are you running?
  3. 71gold
    ...dist. modual...:yup:
    check your dist. ground...
  4. mean_maverick
    running a TFI setup from a '94-95 stang. just replace the stator in the dizzy, had the module checked at Advance and it passed, getting proper voltage and no wire breaks....
    the one thing i dont like about this setup is that it has a remote mounted TFI module that is on a heat sink and bolted to the fenderwell
  5. Mavman72
    Dave...make sure you have 12 volts at the coil while cranking.If its dropping off during cranking...it may be the ignition switch going bad on you.Hope this helps you...Good luck.
    Try a different coil wire too.
  6. mean_maverick
    yup, checked that first.... but thanks Pete. :thumbs2:
  7. PaulS
    Is the module and any other parts of your ignition grounded?
    If you have 12 volts at both sides of the coil it is not grounding and it will never make a spark until it finds a ground.
  8. Joe Dirt
    That is what you should love about it! ford done this to prolong heat related module woes they had for years.
  9. mean_maverick
    but only done it for 2 yrs before they went to the 4.6 :huh:
  10. mean_maverick
    needless to say, im gonna solve most of my problems and go with a different setup (something around a fox body setup) ;)
  11. 71gold
    i just went through this with my ...MSD Dist...it was a...weak ground on the Dist. (-1 volt)
    ...:hmmm:...
  12. mean_maverick
    how does the dizzy have a weak ground when it's bolted to the engine :confused:
  13. PaulS
    Paint, dirt, and grease between the clamp and the distributor. Paint, gasket, dirt and grease between the distributor and block.
    It isn't hard to have some resistance to the flow of those pesky little lektrisikals!
