Comet
Discussion in 'General Maverick/Comet' started by Fatboymaverick, Sep 2, 2023.
  1. Fatboymaverick
    Fatboymaverick Member
    sacramento
    comet
    Hey I have a 71 mercury comet that I put a 5.0 out of a 86 thunderbird with what I think is a c5 transmission can I use c4 transmission lines or do I have to c5 lines. If so does anyone have ideas where?
  2. 71Mavrk
    71Mavrk Member
    Nevada
    Is it an AOD?
    If so, I just grafted the C4 lines near the radiator to 89 Mustang 5.0 AOD lines.
    Micah
  3. Krazy Comet
    I think C5 was history by '86(at least behind 5.0). If it has a bolt on bell it's a C5, cast on bell AOD.
    If it's a AOD be sure the TV cable is correctly set(not on C5), if not line pressure will be low and likely burn clutches first time you drive it.
