I need to grease the control arms (I think that is what they are called) in my mav, the front end is squeaking worse than ever and I can't ignore it anymore, I really don't want to drill holes. Is there any other option?
see Tracy's post on thread http://mmb.maverick.to/showthread.php?s=&postid=690#post690 www.autokrafters.com has a 90 deg grease fitting. I'd contact them for help (I couldn't find the particular fitting on-line). AUTO KRAFTERS, INC. PO BOX 8 • 522 S. Main Street • Broadway, VA 22815 • USA Toll Free (within USA) 1-800-228-7346 • Local 540-896-5910 • FAX 540-896-6412 email: webmaster@autokrafters.com Office Hours: M-F 8:30 am - 6:00 pm, SAT 9:00 am - 12:00pm (ET) Good Luck, Rick
Just put the 90degree kit in my car last weekend. Worked great. The control arms have plugs in them. They are small, can't remember which wrench I used, and are fairly easy to get to. You should remove the wheels. Getting the fittings in is fairly easy, if you use the tool in the kit. Stopped the squeaks immediately. I used a good lithium grease, high pressure and temp. Good luck! Earl
