copper header gaskets won't seal
Discussion in 'Other Automotive Tech & Talk' started by JHodges, Jun 25, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I put a set of copper header gaskets of the fe in my truck because the paper ones leaked. I put the copper ones on and they leak extremely bad. I have all the bolts real tight. I do not have them reversed. Any ideas before I order another set of paper gaskets
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Are the bolts too long and bottoming out before they can really tighten the header to the head? Just a thought.
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    if the FE in your statement is for motor type, are the manifolds the large openining or small. are the gaskets the same as the manifolds. the manifold side has to be perfectly matched, they can be bigger than the head port just not smaller of course.
  4. JHodges
    JHodges thumper
    Dora Alabama
    they match up perfectly
  5. Joe Dirt
    Ive always liked the ultra seal mr gasket's Ive reused the ones on my 429 2-3 times
    Never had luck with copper.
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    That's what I'm thinking. The copper gaskets are thinner than the paper ones. I have the copper gaskets on my old 84 4x4 351W, They have never leaked.....
  7. sierra grabber
    northern nevada
    I run the mr gasket ultra seals that you cut your self as well. however, on your if you have headers make sure the weld on the headers is still thick and flat. you may want to send them back though and go with the ultraseal. better than standard paper and copper IMO. cheaper too.
