coyote 5.0 swap
Discussion in 'Technical' started by Hottrod1991, Nov 15, 2014.
  1. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    I know theirs some guys working on some
    I take if you guys are retaining the factory ECU setup. and using the matching auto?
  2. Bryant
    i have not done this yet. i was talking with someone who is doing this on an old t bird. they didnt know about he wiring portion. i took a look and the biggest problem is going the be the speed sensor. it looks like ford uses the wheel speed sensors for the transmission control. this means thats some sort of wheel speed sensor set up needs to be added to the car for the auto to work.
  3. mercgt73
    mercgt73 Member
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    I guess the other lil snag may be the driveby wire throttle/pedal?
    Ill check out the other links now
  5. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    As for the vss and trans working, it says itll work with a mechanical speedo...so that should eliminate the vss issue
    .as should a gps speedo too..
    I wonder if theirs a y cheaper solutions..
    Too bad theirs not an off the shelve carb intake option
    I was looking at used coyote engines out of the trucks as you can get then for like 2200 shipped to door
  6. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    • What about a manual valve body for 4r70w
    Or simply use an AOD from a modular engine?
  7. Krazy Comet
    No AOD ever had a modular pattern, the early 4.6 that used them had a small block bolt pattern cast on block... Yeah I know, another stupid move by Ford, why they switched and then had to build AODE/4R70W with two patterns makes even less sense...
  8. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Well must not be hard though, read on some forums people running AODs, C4 and gm trans behind the coyote
    I Got to do more digging it seems
  9. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Also i have been reading coyote and mod 4.6 share same bellhousing/ 8bolt crankshaft and flexplate bolt pattern..
  10. mav1970
    I love the "big motor - little car" concept. I'll be watching to see how the build goes :)
    Hottrod1991 likes this.
  11. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    yeah for an engine that weighs around 444lbs and puts out 360hp 380 ft lbs for 2k it doesn't seem like a bad route to go..a d it gets modernized
  12. mav1970
    My Cleveland certainly weighs more than that
  13. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    I did some digging and found a way to use a carb setup via 4.6 intake and custom spacers..but when said and done its essentially same cost with loss of the cvvt?
    I think a good lower cost alternative for transmission would be the use of a 4l80e with coan 4.6 to gm plate/converter and itll hold more power then link posted above
  14. safado
    safado Member
    West Phoenix, AZ
    is the truck motor the same as the mustang motor..internally?
  15. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Same forged crank
    Same exhaust cam
    Different intake cam
    .5 less compression ratio
    Different exhaust manifolds and intake manifold
    Havent looked into the boss 302 but know they have different intake then the other two...and different exhaust cam then the other two
