Crazy Horn!!!!
Discussion in 'Other Automotive Tech & Talk' started by nickmav70, May 25, 2009.
  1. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    i need help with my horn!!
    ok its a 2000 lincoln ls
    the horn sounds at random (just the horn, lights do not flash in unison)
    it does it whether the alarm is set or not
    the steering wheel switch works like normal
    the horn works normal when i set the alarm
    its just haunted and i cant find out why its doing it
    any suggestions will be greatly appreciated
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Clockspring. I'v seen a few on these cars.
  3. nickmav70
    Dallas, GA
    1971 Ford Maverick
    thank you
    i just did a search and it does look like this is a common problem on these cars
    i tried some lincoln forums and noone felt compelled to help me out
    again thanks
    ill see if that fixes it
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    The horn pad is most likely in need of replacing...the surrounding temperature is causing the contacts to make and break connection. Maybe this will help you steer in the right direction
