Different size front/rear tires
Discussion in 'Technical' started by MapleMav, Oct 1, 2003.
  1. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    Out of curiosity, for those of you who run different size tires on the front than on the back, do you carry two different size spares, or do you just take your chances and hope you don't have a blowout?
  2. bmcdaniel
    bmcdaniel Senile Member
    I used to run 2 different sizes. When I had an "open" rear I carried a spare that was the same diameter as the front tires so I wouldn't mess up the wheel alignment if I used it. When I changed to a posi rear I switched to a spare with the same diameter as the rear tires so I wouldn't burn up the clutches in the posi.
  3. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    I carry a AAA card and a cell phone. :D Alot less weight that way. :) Russ
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    I'm with Russ. With 2 batteries in the trunk, not a lot of room for 2 spares. And besides, a 3.5" tire would look awfully funny on the rear! Scott
    :cool:
  5. Maverick Man
    California
    yep the only way to run it on a maverick is staggered. :D
    spare what the hells a spare?
    but i agree Russ.... thats what i pay AAA $45 bucks a year for.. towing up to 100 miles free!
  6. MapleMav
    MapleMav Member
    '72 Sprint
    You guys slay me. :D
    Seriously though, thanks for all the responses. I sure like the staggered look but it's obvious from the responses that there are things that need to be considered when doing it.
  7. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I just have the factory spare in the trunk. Any use would be so temporary that front end pull is not a concern.
    Posi would be, but I have no posi.
