Disc Brake Question
Discussion in 'Technical' started by hotrodbob, Oct 8, 2003.
  1. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Will 14" steel wheels clear Granada Disc Brakes?
  2. Craig Selvey
    You will need to make sure your wheels that you have on the car now have the larger "hole" in the center to fit over the disc brake rotor hub. Small hole.......won't fit.
  3. hotrodbob
    hotrodbob Member
    Ok that's good. I plan on buying some Magnum 500's and if I had to go with 15's then I was going to be stuck as I need tires now and didn't want to by 14's now and have to buy 15's later.
    Thanks
  4. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    granadas and monarchs came with 14 wheels, there was a factory magnum 500 like wheel also as an option..
