dooe 351w heads
Discussion in 'Technical' started by 77mav302, Jan 16, 2003.
  1. 77mav302
    77mav302 Member
    Spokane WA.
    77mav302/2dr, 70mav 2dr
    I have a couple of sets of 1970 351W heads casting # DOOE and was wondering if anyone knows what the combustion chambers CC at stock? I am going to put one set on a '69 302 but don't want to lose too much compression ratio if I can avoid it. I can do the math but don't have a way to CC them myself.
  2. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Stock, they have a chamber size of 60.4
  3. david targhetta
    david targhetta member
    Albuquerque, NM
    1977 maverick w/ 302 V-8
    ya but in 77 they went up 69cc grrr. Also by lowering the combustion chamber volumn by 5.5cc, your compression ratio is raised by 1 full point. Hey CACollo your in Albuquerque. Awesome so am I.
  4. bmcdaniel
    bmcdaniel Senile Member
    When I cc'ed mine years ago they came out closer to 64.
  5. david targhetta
    Albuquerque, NM
    go here i found this site very helpfull. they are 60.4cc
    cynder heads
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Try these
    To heck with 351 heads, try these...
    http://www.araoengineering.com/Ford/frdsmb.htm
    I'm kidding, I never knew that these existed.
    Mine were supposedly 60.4 cc's and they are
    '69 351W heads (C9).
    My machinist cut the bowls, added 1.94,1.60 valves, screw-ins, guideplates, etc.
    and milled them down to 54cc's. He says he cc'd them before he started, but they could have been worked on before?
    With my JE hypereutectic flat tops they yield a calculated CR of 10.6:1
    Runs fine on high test pump gas with .470/.474 lift cam
