driveshaft ?????
Discussion in 'Technical' started by 71gold, Nov 12, 2003.
  1. 71gold
    the driveshaft in my 250 6cyl. is the same size dia. as the 302 donor car. the ?? is . is the 302 2dr. driveshaft longer than a 250 6cyl. 2dr.? when i did my swap the driveshaft does not go in the tailshaft on the c4 as far as it did on the 6cyl. thanks frank...:bananaman :bananaman L.T.N.G.
  2. Mavaholic
    They should be the same length. Mine started as a 200 with 3 spd manual, went to 302 with a c4, then to a 302 with a Borg Warner T10 4 spd, and finally a 302 with a toploader 4 speed. The same drive shaft fit every one.
  3. 71gold
    dennis, the wear pattern on the yoke is about six in. but the driveshaft only goes into the tailshaft about 1 1/2 in. is that enough or should it be more. i have the 4d. shaft i can have cut down. thanks...frank...:bananaman :bananaman L.T.N.G.
  4. Mavaholic
    Thats definately not enough. It should go all the way in untill it bottoms out, then only be pulled back between 3/4 to 1 1/2" when seated in the yoke.
  5. 71gold
    :rolleyes: any suggestions why it might be short...frank...:bananaman :bananaman L.T.N.G.
  6. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Frank is the car sitting on it's wheels or is the rear axel hanging down. Maybe if the rear is hanging down too far the drive shaft is pulling out of the tranny. If the weight of the car was on the rear springs shouldn't that make the yoke move farther into the tranny???? Just thinking out loud. Russ
  7. riporter
    riporter Member
    Charleston S.C.
    Thats strange 71...I used the same shaft on the swap too...no prob...shaft is about 5 inches up in the tranny showing about 1" of clean shaft.
  8. 71gold
    can someone tell me the overall legnth of a 2 door drive shaft
  9. Tinman
    Tinman New Member
    Oxnard Ca
    72 maverick small bumper, 5.0, C-4.
    I avoided all the questions by having a custom 3" dia. drive shaft built for my 72 the stock 6 cyl. shaft got the wobbles at high power.
    (y) (y)
