DS I Coil - 12V or resistor wire?
Discussion in 'Technical' started by Powerband, Apr 18, 2016.
  1. Powerband
    Powerband Member
    NY's \H/
    The 76 Mav 200 has a DS I ignition module and Coil - anyone know for sure if the coil uses resistance wire from switch or does DS I coil use constant 12V with DS I ignition box?.
    thanks
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    'Pretty sure all Duraspark systems use the full 12 volts.
  3. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    I run full 12v to all my coils.. have forever. better spark
