E4OD problem in a 1993 F150
Discussion in 'Other Automotive Tech & Talk' started by Derek 5oComet, Oct 11, 2008.
  1. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Well i just bought this truck and been chasing a problem.First off the trans shifts extemley hard from first to second shift,the speedometer doesn't work but tho odometer does,and i'm getting a ABS warning light on.Now i changed the speed sensor,gauge cluster and the ABS module and still the same thing.All the wiring looks good and seems to check out ok with a ohmeter.I feel i'm running out of options here anyone have any sugesstions?
  2. Derek 5oComet
    Never mind found the problem ,after checking the thing over today i found the problem. High resistance on the green wire for the speed sensor on the rear end running from front to back on the truck.Wohooo everything is good now
