Ecu mounting location
Discussion in 'Technical' started by Streetnstrip, Jul 10, 2017.
  1. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    Im considering eventually going fuel injected with my car so where are you guys that run factory style fuel injection mounting your ecu?
  2. 71Mavrk
    71Mavrk Member
    Nevada
  3. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    Thanks for the idea micah thats a very nice car you have i can only hope mine will be that nice when im done
  4. 71Mavrk
    71Mavrk Member
    Nevada
    Thanks, it is just money and time, plus a little insanity.
    Cannot take credit for the mounting idea. Someone on the list threw it out.
    That was the only good location I could find. I hear others have put it behind the dash. I wish the box was a little bigger. It is a tight fit. Also, think about an easy mounting system for the ECU. It is tough to get in there and a pain to get out.
    I used the Ford Racing harness. It is made by Dunn-Rite. If I were to do it again, I would contact them about adding six to ten inches to the harness by the ECU. It barely reached and is a PIA to get in and out.
    If you go with an electric fan, I highly recommend the Dakota Digital controller.
    If you tune, take a look at the Moates chip.
    Add a second bung to the exhaust for a wideband O2. You can feed the signal through the unused EGR wire to the ECU. You can then data log on a laptop and watch your mixture real time. You might want to preplan for the wiring to the wideband. I wish I would have included in the harness with the stock O2. I did not know I needed until I tried to tune with the POS SCT chip.
    Good luck.
    Micah
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    I have my ECM Velcroed to the bottom of heater/ac .. But if I could have a do over I would not use Factory EFI I would use FITECH EFI system this tuff is so simple and it is self learning
  6. 71Mavrk
    71Mavrk Member
    Nevada
    It can be a PIA especially if you modify the motor. A junkyard EFI system can be easy and cheap to install. Also, I prefer a tuned port system to a throttle body. I think OEM got away from that years ago.
    Comes down to personal preference and cost like everything else.
    Micah
  7. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    I was looking at the space behind the dash just didnt know if the harness was long enough to reach that far
