exhaust leak
Discussion in 'Other Automotive Tech & Talk' started by JHodges, Apr 17, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I have a 69 F-100 with a 390. It has longtube headers on it. I had the heads rebuilt. It seems like the truck has an exhaust leak. I have new collector gaskets on it and the bolts are tight. I believe the leak is coming from where the header bolts to the head. I have tighten the bolts a couple times but it still seems to leak. The gaskets are also new. Any help is appreciated
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Get a set of the copper header gaskets. They are pricey, but won't blow out and leak like the paper ones do. I have them on my old 84 pickup. It would blow out the paper ones in just a few days. The copper ones have been on it three or four years, no leaks...
  3. JHodges
    JHodges thumper
    Dora Alabama
  4. ford84stepside
    Berry Alabama
    Those should work. I got mine at Advance, Mr Gasket brand, about the same price IIRC....
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    Question - Did everything work prior to the cylinder head work? Meaning the headers were on the truck before, without any problems? Same cylinder heads?
    I have a friend who had a similar problem with new headers. They found out that there are different truck headers with different sized exhaust ports.
    A mismatched big hole and little hole would not seal. Bolt spacing is all the same.
  6. Comick76
    Comick76 Grease Monkey
    San Angelo, TX
    76 Comet
    Make sure the headers are straight. A couple of months back I did a head job on a 68 f100 with a 360. headers didn't leak before the job but, were warped when I took them off. I had to replace them.
