floor shifter
Discussion in 'Technical' started by warboy, Oct 26, 2016.
  1. warboy
    warboy Member
    pennsylvania
    1972 ford maverick grabber, 1977 ford maverick 4dr 351 v8
    i want too put a nice hurst shifter or b&m shifter in my maverick. i want to keep the bench seat but i dont know which shifters can be installed without having trouble with the bench seat
  2. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    Most of your aftermarket shifters are cable controlled so you could mount them pretty much anywhere as long as the shift cable is long enough.
  3. Hotrock
    Munroe Falls, Ohio
    Here are some pictures of my Comet with a bench seat and B&M shifter.
    BHARP4343 and rotorr22 like this.
  4. BHARP4343
    BHARP4343 Member
    MN
    1972 Mav
    Did you have issues with the neutral saftey hookup?
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Why??
  6. BHARP4343
    BHARP4343 Member
    MN
    1972 Mav
    We are installing a b & m in my 1972 302 v8. Column shift.
    We are having a hard time figuring out the neutral saftey.
  7. Hotrock
    Munroe Falls, Ohio
    I bypassed the neutral safety switch in the column and wired up the switch in the B&M shifter.
  8. BHARP4343
    BHARP4343 Member
    MN
    1972 Mav
    ok thank you
  9. 71Mavrk
    71Mavrk Member
    Nevada
    Some people, including me, remove the steering wheel lock to prevent the possibility of it engaging when you don't want it to.
    Micah
