For those with '85 and up 302s...
Discussion in 'Technical' started by Atzy1, Feb 16, 2003.
  1. Atzy1
    Atzy1 MMB Sporadic Participant
    Bremerton, WA
    '75 Maverick 4d (302, AOD, MSD, PST); '77 Maverick 2d (302, C4)
    Question...
    Do you have a V-belt system on your '85 up 302? If so, what year/model combination of timing chain cover, water pump and accessory brackets are you using to make it work?
    Thanks,
    Atzy.
  2. Atzy1
    Bremerton, WA
    Sorry, meant '81 and up...n/m
    n/m
  3. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    I do
    I'm running a v-belt system on my Maverick. It's an 82' 302 with just an alt. at the moment. I stole the crank pulley off a 351w that I have and used the alternator brackets too. In fact I think I took everything off the 351w too make it work. You may have to space the fan pulley a bit with washers. I don't think I've done anything wierd. I'll see if I can get some pics.
  4. Atzy1
    Bremerton, WA
    Cool...
    What year/model timing chain cover are you using, and does it interfere with anything? Is your dipstick up forward or somewhere in the back?
    Thanks,
    Atzy.
  5. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    pics
  6. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    more pics
  7. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    more
  8. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    more
  9. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    more
  10. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    last one
    I hope this helps some. I used the 82' timing cover although I may drilled out a hole for the dipstick and plugged the hole in the oil pan. Don't mind my messy and multicolored engine bay I'm planning on fixing that in the summer when there isn't a foot of snow on the car.
  11. Atzy1
    Bremerton, WA
    Cool again...
    Your alternator mounting looks just like mine, is that an '82 water pump too?
    Continued thanks,
    Atzy.
  12. Mavstang73
    Mavstang73 Member
    CT
    Sold the Maverick
    Actually that is the cast iron water pump that was on the 351w. Eventually I will change it too an aluminium to lose a few pounds. I hope this info helps. Seting this stuff up requires a little imagination if you don't have a similar setup to look at.
    I know I tried a few different methods myself.
  13. Atzy1
    Bremerton, WA
    Thanks!
    Great info there. I have a '77 timing cover with an '85 block and aftermarket balancer, and I'm getting some interference. I hope that with a '81 up timing cover and one of the water pumps I have, I'll be able to make it all work.
    Thanks for the help!
    Yours,
    Atzy.
