Ford Taurus Fan 250ci
Discussion in 'Technical' started by Butters, Jul 16, 2016.
  1. Butters
    Butters Member
    Colorado Springs
    1970 ford maverick
    im looking to up grade my stock mechanical fan for something better on these hot days the car likes to get to 200-210. I have a 190 thermostat works great on cooler days not so much on hotter days. Right now it's a 250 6 cylinder/c4 all stock with all new hoses heater core and thermostat and radiator has been flushed. I'm going to put a 302 in it later and know how to do the fan for that but want to keep it cooler now so I can enjoy driving it and not worry about it. Looking to see if anyone has done a Taurus fan to a 250 I 6 or the 2 extra cylinders make it impossible to fit(which on test fit it seems) and advise or pictures would help. I will just try a flex fan with a upgraded radiator if all else fails.
  2. Krazy Comet
    Anything under 225*F is fine, I would not worry about it ...
  3. rthomas771
    Using a lower degree thermostat will help to put the fire out before it gets to hot
  4. 71Mavrk
    71Mavrk Member
    Nevada
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Jamie Miles on this form did a taurus fan on a i6 try to search it was a long time ago .. s for a controller the volvo is the best bang for your buck form 6.00 to 10.00 dollars at your local junk yard or 50.00 dollars at NAPA you will still need to get connectors from the jyard
    Butters likes this.
  6. Butters
    Butters Member
    Colorado Springs
    1970 ford maverick
    I hear that a lot but I'd rather have an electric fan it's what I want
  7. Butters
    Butters Member
    Colorado Springs
    1970 ford maverick
    Yes but our winters get in the negatives and the heater works great during this time and I'd like not having to change the t stat out every season haha
  8. Butters
    Butters Member
    Colorado Springs
    1970 ford maverick
    Thank you I am just going to be using the Volvo relay for now through a 3 way toggle switch for budget wise.
