fuel lines
Discussion in 'Technical' started by merc1mack, Sep 29, 2003.
  1. merc1mack
    merc1mack merc1mack
    North Carolina
    comet
    Hi guys, I have removed the tank from the Merc1. I got a buddy to coat it to get rid of the rust. Now I am curious about replacing the fuel lines. Yes, or no? I have replaced the rubber connections in between the metal fuel lines.
    Also, I plan to paint the tank and the underneath of the car. Any ideas?
  2. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    If the stock fuel lines are showing signs of corrosion it may be a good idea to go ahead and replace them. There are many choices when changing fuel lines but my advice would be that if you plan on any performance upgrades in the future you may want to install a bigger than stock fuel line. There are many types of fuel line available, stock replacement, stainless steel, aluminum, teflon lined stainless braided.........just gotta ask yourself how much you want to spend. For the painting under the car I would use POR-15.
