Fuel tank sending unit
Discussion in 'Technical' started by mywifeisawesome, Nov 12, 2016.
  1. mywifeisawesome
    mywifeisawesome Member
    Pittsburgh, Pa
    1973 Mercury Comet
    Hi everyone. I was wondering how to check too see if my sending unit is bad. Do I just unplug it and ground plug? If the gas gauge shows full when grounded will that mean sending unit is bad? Thanks
  2. Krazy Comet
    Grounding plug is one way, if gauge pegs problem is no doubt in tank...
    Note never leave one grounded longer than just a quick check, otherwise the calibration of gauge can be effected...
  3. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Thanks Krazy Comet. I'll give it a shot here tomorrow or monday. I'm hoping its the sending unit.
  4. 71gold
    what problem are you having?
  5. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Gauge on dash doesn't read anything
  6. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    I just had this happen. I pumped the tank down, removed the pick-up / sender assembly to find the brass float had a hole in it. Repaired the float, reinstalled it, added gas and now all is well.
    71gold likes this.
  7. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Thanks quickshift, I'll check that also.
