fuses
Discussion in 'Tool & Shop Talk' started by Payette 302MAV, Oct 12, 2010.
  1. Payette 302MAV
    Payette 302MAV Member
    Payette Idaho
    1970 Maverick 302 painted Bahama Blue Metallic.
    one of my fuses went out on my '70 maverick and i cant read what the fuse box says it shoud be. its the one for my accessories. the one i pulled out was a 15a 32v but i cant find the same type but have tried close ones with the same rating.
  2. maverick75
    Use a 20a 32v.
  3. Payette 302MAV
    Payette Idaho
    ok thank you ill try it
  4. maverick75
    Edit i messed up i meant a 20a one. But the yellow boxes of BUSS fuses come with a 15a one, you can get it at any parts store. Or even a has station.
  5. Payette 302MAV
    Payette Idaho
    20a 32v or 20a 12v.....
  6. maverick75
    Any should work. The number is just the max rating. Cars run on 12v so you should be able to use the 12 or 32 one....
  7. Payette 302MAV
    Payette Idaho
    thats what i thought it was the max rating, and ya i knew that it was a 12 volt system in most vehicles. hey thanks ill try that and see what happens
  8. PaulS
    Take the bad fuse with you to the parts store. Fuses come in all kinds of lengths and amp ratings. The voltage rating makes no difference. A 15 amp 250 volt fuse will still blow if you go higher than 15 amps with 12 volts.
