Installed a new fuel sending unit and fill tube. Gas gauge doesn't read correct. Is that fixable and how?
may need to adjust the float wire, I set mine to read empty with 2 gals. of gas left...like a 30-40 mile reserve...
In tank fuel sending units seem to always need some tweaking by bending the float rod I know it is an inconvenience to not show full but it is more important for it to correctly show empty even if it has a couple gallons left in the tank when empty. Some times its best to leave well enough alone as it is a hassle to drain tank to lower gas level pull unit bend rod put back in and then do it over again
I put 2 gals. in and check gauge. if not correct, I jack up drivers side and pull sender. after making adjustment, repeat process if needed. I also install drain plugs in all my tanks...(an O2 sensor bung with oil pan drain plug works great for this).
