Gas tank vs. Fuel Cell installation-Opinions
Discussion in 'Tool & Shop Talk' started by tonyj71mav, May 10, 2008.
  1. tonyj71mav
    tonyj71mav Member
    Upper Marlboro, Maryland
    I recently removed my gas tank from my 71 Mav lots of leaks . I wanted to replace the tank but there's so much drama with the finding the old tanks and making necessary conversions for a new tank. I am debating about putting in a 16 gallon fuel cell can I get some pro's and con's on this idea. I know some of you have gone down this road.
    :feedback:Thanks, TonyJ
  2. don graham
    I only have one in my race car, but I'm not sure you can get a fuel guage in the cell. also it'll probably take up a lot of the trunk room unless you build a frame for it to drop into. May not be big things now but they tend to become a hassle later on.:)
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    http://gastankrenu.com/ This is the way I would go! Cheaper ways of doing it, but My opinion none better! Fuel cell gonna cost more money till you get all made up and get gauge set up. renu will patch all holes an make like new with the coatings you never get any rust in gas from water in tank! Moyers in Greensburg Pa does excellent work! Good Luck
  4. tonyj71mav
    tonyj71mav Member
    I spoke with a Renu company here in Rockville, Md (no Flintstone jokes please) the cost to blast the tank, inside and out, seal and recoat would cost between $299 -$499 with a guarantee. Its then a matter of setting the tank in place and hooking back up the lines. Seems like the simplest and most logical thing to do.
  5. HARRYJOHNSON
    HARRYJOHNSON Member
    AZ USA
    COMET 73
    go on ebay you will find a gas tanbk replacement
  6. rthomas771
    What drama is there in buying a new tank for a 76? All you need is longer bolts from Home Depot or any hardware store. The vent hardware is still available from Ford. Total cost for new tank and hardware about $120 And that's a lot cheaper than putting a band aid on an old tank
  7. rayzorsharp
    Read Mavaholics article using the Mustang tank. It will also give you more clearance for dual exhaust. Mustang tanks and senders are very cheap!
  8. rayzorsharp
  9. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    Check with your local radiator shop. I had 2 quarter sized holes in mine along with hundreds of pinholes. A rad shop in town soldered and recoated the tank inside and out for around 140.
  10. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    By why go through the efforts to do that, when you could order a brand new one....
    Touch it once!
  11. 71gold
    thread is 5 years old, wonder if he got it fixed by now and what direction he went...:huh:
