getting stuff put together and noticed something
Discussion in 'Technical' started by Will, Jul 11, 2003.
  1. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    Well, I've got my tranny and motor in. I hooked up my driveshaft, put some atf in the tranny. I'm moving around in the garage and the tranny is in gear but I can still roll the car around, no matter what gear. Everything should be hooked up, except the starter is not in. Besides that driveshaft spins and so does the yoke on the tranny and rearend. Something is odd and I cant figure it out. Will it still roll without the starter??
  2. courier11sec
    courier11sec Member
    Tucson, AZ
    Will-
    What ans are you running?
  3. Will
    Will I
    Waco
    oh ya, that might help, a T5
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    Weird problem.
    I think I'd double check your clutch set up to make sure it's fully engaged and your shifter mechanism to be sure you're actually in gear.
    Your transmission, is it a known good unit?
    Hope you win,
