Granada front disc brake conversion
Discussion in 'General Maverick/Comet' started by Comet79, May 1, 2022.
  1. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    Hello everyone, so I went with the Granada disc brake conversion, but somehow I ran into a lil problem. I'm having issues with the hydraulic brake hoses. So once I installed them I noticed that when I steer left or right the metal portion of the hoses get on the way between the steering stopper and the lower arm. Therefore the steering is very limited and if I would try to drive those hoses might brake. Did anyone run into the same issue and hopefully have a solution for this. Thanks in advance.
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    I’m thinking you may have the calipers swapped from right to left. The brake hoses should be coming straight out parallel to the ground from the top half of the caliper pointing towards the front of the car. If it’s angled down and interfering with the steering stop, I bet they are swapped/on the wrong side.
    Not my picture, but they should look like this: upload_2022-5-1_21-31-54.jpeg
  3. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    Wow, I'm going to swap them out. I'm sure you are right about that. I thought to myself that they're shouldn't be any reason why this was happening to me when i know a bunch of people have done the same conversion as i have and i haven't heard any issues from it. Hey thank you so much for your input. I can't wait to get that job done :thumbs2:
  4. rthomas771
    FYI...Early Granada used Maverick brake parts...same part numbers
    allen nicely and rickyracer like this.
  5. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    Thank you guys, I had them swapped and now they are correctly installed.
    rickyracer likes this.
