Granada Tilt Wheel?
Discussion in 'Technical' started by Corbin Johnson, Oct 6, 2002.
  1. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    I was just thinking about how some Granadas had tilt steering columns, and I was wondering if they would fit in a Maverick. I know that Granadas were based off the Maverick platform, but I don't know how similar the steering columns are. My first impression is that they won't swap, but I may be wrong, so I posted this idea. Anyone tried, or actually done this swap? Thanks.
    -Corbin
  2. Manimal
    Manimal Member
    Portland, Or
    70 Mav heap
    I read something on a Mav web page a long while back where a guy gave a step by step R/R on a tild column. Donor car was a early 90's Tauras if I recall correctly.
  3. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    that's mark at maverickcomet.com
  4. RabidCustoms
    I did a tilt column years back using a 80?something mustang column, was the year before they went to airbags....worked great just had to shorten the shaft a little. wiring was something else but liked the way it worked and the new position that the wheel adjusted to.
  5. Corbin Johnson
    RadMav, do you happen to have any pics? While I won't attempt to do this swap now, I am thinking about it in the future, and would like to see how it turned out if you have any. Thanks.
    -Corbin
  6. RabidCustoms
    sorry corbin, I dont have any pics of it,...nor do I have the car anymore,....didt think to take pics when I didn it,..but I can tell you it fit very nicely and didnt require much to modify to fit, bolted right in the stock location. the 77's dash sealed up around it like it came that way
  7. gregjsmith
    gregjsmith mavmac
    Albuquerque, NM
    1972 Ford Maverick Sprint
    That was mine. Still intend to use that got the wheel to fit on the mavericks steering wheel mount and the wiring for the Ford "multi-switch" to mostly work.
