Head Bolts or Studs?
Discussion in 'General Maverick/Comet' started by Renton5, Apr 22, 2023.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hi, Everyone!
    I have a '71 Mav with a 200 (no ac, no power steering or brakes). Having drained the radiator to get a leak fixed, I decided to get the valves serviced, replace the clickety valve lifters, check the pushrods, etc. I came upon a video that showed the use of studs instead of using bolts. What are the thoughts out there about using studs?
    Also, I'm considering replacing the exhaust manifold because I'm afraid of snapping the bolt holes in this
    52-year old piece of iron. With the head off, I'll also be replacing the ex-manifold studs--or have the machine shop do it. Is there a recommendation for a made-in-America ex-manifold, or is that as rare as a unicorn?
    Thanks all!
    (I'll also change out the timing gears and chain. Who do you recommend?)
  2. CaptainComet
    Head studs are usually an improvement over head bolts. Better clamping force and easier to get the torque values right. They can get tricky on a V8 in some cars because they complicate taking the head off while the motor is in some cars, but on an I6, where you lift the head straight up there should be no issue in a Maverick.
    Not sure about the exhaust manifold, or what you are asking. If you need to replace yours, another member here likely has one. Pretty sure some older Mustangs and Falcons had this motor, so they should be common enough. I would probably have a machine shop make sure the mating surfaces on the head and manifold are flat, maybe do a light clean up pass on them.
    Shorty and mojo like this.
  3. Powerband
    Powerband Member
    NY's \H/
    NICE !
    Early Maverick base model with a 200 is simple honest car with rep' for easy repairs or upgrades.
    Auto or Stick ?
    Replacement OEM Exh. manifolds available from many vendors , fancier tube Headers are also available for a price upgrade
    inspecting/replacing 'valve job' accessible parts like lifters and timing set is a good idea while head is off.
    'valve job' upgrades can include back-cut valves, SBF V8 valve springs and modern valve guide seals .
    Head Studs are good idea if head is frequently R&R'd . OEM head bolts are fine for mild performance and ARP bolts are recommended for serious compression or forced induction.
    plenty more info on optimizing performance of the Ford Small Block Six over at :
    https://fordsix.com/
    manifold
    https://www.falconparts.com/ford-falcon-auto-parts/pc/EXHAUSTS-c66.htm
    https://www.ebay.com/itm/166010910272?hash=item26a7057640:g:Eu8AAOSwSDJkKKFf&amdata=enc:AQAIAAAA4LAw6iOUs1VIDwjJV7BfvZSzcrE1K7U7XnkjDCImm70SEpeCjJmu6xDI3eeyDwzEF3YTaIf7kRD6H2sqf3ixjvZlIPJse9FZpqVG+T+QRTFVAEU9yzjrZ0GPFHTATk9jX/W0In99N0rEPSTWZYfzak6CsjHi8uPTB4FOm1Uv4Fq2fh089Y2/JXr84VK0ujEid9IYjbs7jLjtZapgNg5r17DUTKXOPKbonk+2kwBjsn4bm4PkqKjj0g7FRDgI4Sdn1vjGQH4lEPOZnBPvHveCwT5zgVfABJxLyamrWr3jfHkJ|tkp:Bk9SR5ztzOX1YQ
    Ford Small Block Six 250 CID inline . Stock block and cam with blueprinted matched 60 cc chamber head, HD V8 valve springs, ARP head bolts. Holley 2300 - 7448 2Bbl heavily modified for blow-through/ boost, Aeromotive 1:1 boost referenced regulator and FI electric pump and return at tank. Flame Thrower rev-limited HEI ignition - DS II distributor modified for vac and centrifugal boost advance limiting. Vortech V-2 centrifugal supercharger with pulley ratio spec’d for inline six 250' powerband. Centerforce weighted clutch, T5-Z 'Cobra' 5 Speed, 3.80 rear. AM radio and bench seat.
    [​IMG] . [​IMG]
  4. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    Tne best thing to do is swap in a 302 rather than spending money on a 200 inline 6...
  5. Powerband
    Powerband Member
    NY's \H/
    many options for '71 Maverick enthusiasts, most likely with a six ...
    1971 Maverick Production :
    V8 Engine: 11.2%
    I6 Engine: 88.8%
    .. many options
    Krazy Comet and mojo like this.
