Headlight Switch Removal?
Discussion in 'Technical' started by Deerhog, Dec 30, 2018.
  1. Deerhog
    Deerhog Member
    Texas
    1973 Mercury Comet GT
    I know this may seem like a really basic question but I was wondering how to remove the headlight switch. It seems like a pain to get to the back of it from underneath the dash. Do you uncrew something from the back or front of the switch or what is the best way to get it out? Thanks.
  2. Acornridgeman
    Wisconsin
    You will need to pull the cluster and then you can reach it easy enough. Helps to have small hands. :yup:
  3. dyent
    dyent Member
    vancouver bc
    Put on some sort of tight fitting, mechanic type gloves, helps prevent getting cut up from sharp sheet metal edges etc........
    David
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    There is a button on the bottom of the switch that when pushed in will allow the knob and shaft to be pulled from the switch. After the shaft is removed you can use a large phillips head screwdriver to remove the "nut" that holds the switch to the dash. You will then have to unplug and remove the switch from the back with the cluster removed.
