Headliner question
Discussion in 'General Maverick/Comet' started by RudyD, Mar 25, 2002.
  1. RudyD
    RudyD Pretend Mechanic.
    Ft. Collins, Colorado
    1970 Maverick.
    I am getting a new vinal top put on the mav on the 1st, there is a small dent on the roof though and I want it to be perfect. I think that a light bonk with a rubber mallet from the other side will pop it right out. The problem is that the dent is in a crappy location. It is above the driver rear vent window up on the top part of the roof toward the back. I will post a pic ASAP. Is there any way to take my headliner partially out without needing to replace window rubber? Any other idea's for pulling the dent? It is a small dent with no dramatic edges.
    Thanks,
    RudyD
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    A cheap solution might be to get a suction-type dent puller. Harbor Freight has one for $5.
    http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40993
    You might also consider putting a seft-tapping sheet metal screw in the middle of the dent to pull it out, then smooth it over (if it's going to be hidden by the vinyl). Or, Harbor Freight has a device based on that theory. Those are also cheap ( not necessarily 'inexpensive').
    Good Luck,
    Rick
  3. jeremy
    jeremy I build t5's
    Corona, Ca
    If the dent is really small, a rubber mallet, or suction cup may not work, be careful trying to push it out. I started some paintless ding removal lessons once, and you can do a lot of damage, I would suggest going to one of those paintless ding removal places and paying them a few bucks.
  4. RudyD
    1970 Maverick.
    RudyD
    I guess I should clarify my definition of small. The dent is about the size of a softball, very shallow though.
