Hedman 88308
Discussion in 'Technical' started by Scotty P, Sep 23, 2003.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    Well, the installation was a breeze. With homemade motor mounts they slid right in my 1970. Only had to lift the car 18" or so. BUT....... With the thicker flanges (they are ceramic coated) I can not get a plug socket on the plugs!! Any ideas? Are there thin walled sockets out there? VERY thin wall...And they look so good too.. At least they won't get dirty if I can't get the plugs snug!
    :cry: Scott
  2. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    Remove the bolts that hold the header then snug up the plugs, with the plugs tight you can bolt up your header. That is what I did with my chevy until I cut away 1/2 of a socket.
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    Thanks, I think!! Did a thinwall help out at all? As you know, the headers are not the easiest bolts to get to sometimes. Always looking for an easier way!! Scott
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    Ah Ha a regular spark plug socket and 10 minutes on the bench grinder and whola! a thin walled socket that fits past the hedders. Thanks for the tips...Scott
  5. shelby j
    shelby j Member
    Delano, Minnesota
    Hey Scott, what size engine did you put those headers on?
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    302 with 289 heads.. Scott
