I have a 200 6 cylinder with a C-4 automatic. How is the kick down lever attached to the kick down linkage and the throttle body? I rebuilt the engine and when we hooked it up you had no passing gear because the lever fell down into the throttle body and do not know how to hook it back up. A diagram would be great! Any help at all would be awesome!
Kickdown lever Need some more info here, by throttle body are you referring to the carburetor or the valve body on the trans?
