Horn issue.
Discussion in 'General Maverick/Comet' started by wolfheads, Nov 17, 2022.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I know I posted in another thread, but is there a horn relay in my 73 maverick? if so, where is it located?
    Thanks.
  2. bmcdaniel
    bmcdaniel Senile Member
    If your car is like my '70 there's no relay. The horn button gets power from the circuit breaker built into the headlight switch. If your lights work, that's not the problem. Does the horn work connected directly to the battery? Also, the horn bracket has to be well grounded to the body.
    mojo, jasonwthompson and 71gold like this.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    X2 on that. I added a HI horn to the car as I did not like the anemic sound of the single LO. In my case, the paint on the horn and bracket was enough to insulate it and prevent it from working correctly.
  4. Krazy Comet
    No relay..
    As mentioned, horn circuit is fed from circuit breaker built into HL switch. Circuit splits inside switch, if brake lights operate the switch is OK. Generally park & dash lights are also out.
    wolfheads likes this.
  5. wolfheads
    wolfheads MadMav
    Florida
    OTE="bmcdaniel, post: 1170910, member: 302"]If your car is like my '70 there's no relay. The horn button gets power from the circuit breaker built into the headlight switch. If your lights work, that's not the problem. Does the horn work connected directly to the battery? Also, the horn bracket has to be well grounded to the body.[/QUOTE]my lights work. There's no power going to the horn wires behind the steering wheel.
  6. bmcdaniel
    The horn switch power wire comes from a light green/red wire at the turn signal switch connector on the steering column that, in turn, comes from the light swich. The other wire that goes to the horn connects to a dark blue wire at the turn signal connector.
