Horn
Discussion in 'General Maverick/Comet' started by wolfheads, Mar 29, 2022.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    Does the horn have a fuse ? It was working and now it doesn't. I removed the steering wheel thinking it wasn't getting a good connection. I checked the wires and there is no fire on either wire.
  2. Acornridgeman
    Wisconsin
    It does, but not in the fuse block or something you can get at easily.
    It is a 5A integral fuse with the headlamp switch. If your stop lights and the side markers / parking lights and licenses plate light are working the fuse is good.
    Horns often go bad with age and the horn switch in the steering wheel is very prone to the plastic breaking with age. If you have the contacts in the steering wheel exposed, you can short them to test. But that only works if you know the horn itself is working. You can pull the horn and put 12v to it to test it.
    mojo likes this.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Do the Mavericks have a horn relay? Mine has been apart for so long I can't remember!
  4. 71gold
    mine does...it came with the RF wiring/fuse box kit I bought.
  5. mojo
    No relay on my car from factory. I added Bosche type relays to horn, headlights and extra horn.
    71gold and RMiller like this.
  6. RMiller
    Kennewick, WA
    I didn't remember seeing one but it was a long time ago!
  7. Craig Selvey
    Check to make sure the horn still has a good ground to the apron. Take it off, clean the rust off the bracket where it touches the apron. Do the same with the apron spot.
    mojo likes this.
  8. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    No but i think everyone should add one.
    I also added a fuse.
    old55guy and mojo like this.
  9. bmcdaniel
    bmcdaniel Senile Member
    Once upon a time, decades ago, my horn stopped working for no apparent reason. I sprayed WD40 inside and it has worked ever since
    CaptainComet and Krazy Comet like this.
