How do you jump the starter bypassing the solenoid?
Discussion in 'General Maverick/Comet' started by mrcomet, Aug 29, 2024.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Hello All,
    I am trying to test everything. I tried to jump the stater bypassing the solenoid. I hooked a battery cable to the positive battery post and touched the other end of the cable to the starter terminal. All I got was a spark then it started to burn. I had the key on the ignition.
    Did I do this right?
    Thanks!!
  2. Krazy Comet
    It should have cranked, possibly solenoid is shorted to ground.
    Disconnect starter cable from solenoid, then touch cables together, should crank. Except that starter does/doesn't operate, it's not proof positive of anything else.
