Hydraulic Clutch
Discussion in 'Technical' started by dopeeye, Jun 29, 2003.
  1. dopeeye
    dopeeye Member
    Orlando,Fl
    1976 Maverick
    Does anybody know where I can get the slave cylinder along with a bracket for the hydraulic clutch set up on a T5.
    Thanx
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Try a local salvage yard, or I am sure Autozone would have the slave, dont know bout the bracket.
    Dan
  3. mavman
    mavman Member
    Arkansas
    did a T5 use a hyd clutch from the factory?
  4. dopeeye
    dopeeye Member
    Orlando,Fl
    1976 Maverick
    The T5 never had a hydraulic clutch setup. It came of a Mustang with a cable linkage. :p
  5. gsjohnson
    gsjohnson Member
    Pasadena, California
    72 Maverick 5.0 EFI
    JME makes the bracket & slave for a T5. 858-627-9886. Hope this helps. What are you using for a master?
