I gotta leak, well the Mav does
Discussion in 'Technical' started by hotrodbob, Sep 15, 2003.
  1. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    I washed my new Mav for the first time yesterday and the passenger side front floor got wet and the a/c duct under the dash. Do Mavs have the same problem Falcons and rustangs had at the cowl vent?
    How hard is it to fix?
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Unfortunatly, Mavs and Comets have that same problem. Also unfortunatly, it is quite expensive and a lot of work to fix them. Quite a few members on the board have successfully fixed them, and they can tell you more about it. Below is an attached link to a FAQ topic, written by Craig Selvey, about fixing the cowls. However, before you go ripping away, make sure that the cowls are the culprit. Is there a great quantity of water? Is you windshield leaking, perhaps? The easiest way to check the cowls are from under the dash. It may require you to remove the a/c box and related to be able to see what's going on. Try searching for cowl vent repair to find more info, too. Hope this helps, and I am hoping it's your windshield!:)
    -Corbin
    http://maverick.to/cowl_faq.php
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I'm glad you were the bearer of 'potentially' bad news, Corbin.
    I didn't wanna say anything. :(
    Good luck with it, Bob. Maybe it's just a minor repair.
  4. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    yes the cowls rust, mine did very badly. im not yet through my repair though.. id post a pic, but its pretty grusome and i've been asked not to post it anymore :D
  5. Corbin Johnson
    Yeah, I didn't really want to, but then I figured I might as well bite first. I would want to know as soon as possible about what may be occuring if it were me, so I figured Bob would as well. Best of luck!
    -Corbin
  6. hotrodbob
    hotrodbob Member
    Corbin & Rick, thanks for the info. Yea it was a lotta water. Top of the dash was dry. Didn't see any leaks there.
    A/C duct on the right side was wet. I'll have to climb under and look further and check out the info you recomended. This was a local So.Cal. car with no rust any place so this came as a surprise.
    May have a body shop friend just fill in the cowl vent and make the cowl smooth.
    Thanks again guys!
  7. hotrodbob
    hotrodbob Member
    The story on the repair was enlightening. Oh boy do I have some work ahead of me. Well I hope it's not that bad. I'll investigate it this week end.
