i need help
Discussion in 'Technical' started by badazmaverickv8, Oct 5, 2003.
  1. badazmaverickv8
    badazmaverickv8 Member
    salem,va
    1974 maverick 302 2dr at
    i got a busted rear main seal dose any one have info to help me besides take it to a shop
    thanks
  2. Lightning
    Lightning Member
    Saskatchewan ,Canada
    1971 comet GT
    Some will disagree perhaps but I find the easiest way to fix that problem is to pull the motor out put it on a engine stand flip it over and change the seal .
    Or , lay on your back ,move whatever is in the way out of the way underneath ( steering ,crossmember ) pull the pan off , and change it that way .
    I hate laying under cars . My arms run out of blood too fast nowadays . :)
  3. badazmaverickv8
    salem,va
    thanks 4 the help
    is pullin the moter out to hard what all do i have to disconect i no the moter mounts the trans and what else but thanks 4 the tip
  4. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    the fuel, line the coil ,the ps pump , the rad ,and some smog stuff.
