Kick panel speaker size
Discussion in 'Audio' started by maverick1970, Apr 30, 2005.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Figure I would break in the new Audio area.:bananaman:bananaman
    I have a set of kick panels with the speaker grilles in them and was wondering what speaker sizes you guys and gals have installed behind them. I currently have 4 inch speakers in standard kick panels but just don't get enough out of them. Looking to go larger, 6.5's?:D
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Here's what I put in my 74 behind the factory speaker grill kick panels.
    http://www.brilliant-electronics.com/car_speakers_pyramid_526dc.htm
    You need to get as thin a speaker as possible or it will not fit behind the kick panel because the door hinge bolts are in the way. Also ... the 5 1/4 speakers listed above lined up with the factory screw holes for mounting ...
  3. maverick1970
    Missouri
    Thanks Dan I remember asking you this before but I could not find your response message. I want to try to get 6 1/2's to work. Infinity makes a 6 1/2 shallow mount (1 7/8 deep)
  4. dmhines
    Cumming, GA
    1 7/8 would probably hit the bolts - these are 1 1/2 and they are pretty close to hitting ... you could either shave down the door hinge bolts or put a small spacer between the speaker and firewall if you had to so you should be OK.
  5. Comet155
    Comet155 Member
    Put in 5.25 inch Infinity Kappas. Good fit and pretty close match to the factory sheet metal openings.
  6. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    I have used both 6 1/4 and 6 1/2 inch speakers in that location. As long as they are a "shallow mount" speaker, you'll be just fine!! Good luck and say hello to the family for me! Preston
  7. maverick1970
    Missouri
    Thanks Preston, will do!
