lights on buzzzzzer
Discussion in 'Technical' started by 71gold, Oct 13, 2003.
  1. 71gold
    i would like to add a buzzer to my lights so i want leave them on. could someone suggest how to wire them. it is on my 73' grabber. thank you very much...frank...
  2. Mavaholic
    This could be done with a few parts from Radio Shack. You'd need two 12v relays and a 12v buzzer. You will need 3 different 12v sources to make it work. A constant 12v to feed the buzzer, a 12v line switched by the parking lights, and a 12v line switched on when the key is in the run position. Then just hook them up like the diagram.
  3. 71gold
    thanks mavholic, i will try this. i no not elect. with the pic. it should be a breeze. you got p.m....frank...
  4. tom mulloy
    tom mulloy Senior Vice President
    Green Bay, WI
    1970 Grabber
    In the past I've used a headlight warning buzzer that cost about 5 bucks. Not sure where I bought it, either WalMart, or a local auto parts store. It's a little white plastic box (about 1" by 1/2" by 1/2") with 2 wires. One goes to ground. The other one taps into the instrument panel lights fuze (forget which side). Sounds a little tinny, but you definitely can't miss it.
  5. 71gold
    thanks tom,:clap: :clap: between you and mavaholic, i should be "buzzzzzzing" in no time.:bananaman :bananaman :bananaman ...frank...L.T.N.G.
  6. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Great little bit of info, I have to admit there have been a couple of times that I have left my lights on, only to come out to a dead battery. I guess the modern conviences of the newer models do spoil you!
    71gold, let us know how you make out on this one.
    Thanks,
    Dave
  7. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Sounds like a great little addition for my Mav. If I ever get the time, I'll add this to my list of things to do. Thanks, and if you complete it soon, 71gold, let us know how it went. Thanks.
    -Corbin
