little help with grabber spoiler installation
Discussion in 'General Maverick/Comet' started by redfivexw, Oct 24, 2013.
  1. redfivexw
    redfivexw Member
    I have a 70, just got a grabber spoiler. I used the search to find some advice on using the studs from the spoiler to mark where to drill, and drilling 1" holes. My only question is do you drill on the peak of the trunk lid, leaving a hole that is 1/2 on the top and 1/2 on the rear? Anyone have a photo of a trunk lid with the holes so i can see?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You are correct, just center punch them on the peak
  3. 71gold
    this is Collin drilling the holes in his trunk lid lip...:thumbs2:
    don't forget to seal the holes...:yup:
  4. predfan2001
    I wish there was a tech article on how to align these spoilers once installed. I drilled my holes where its recommended and the left side doesn't fit right. Maybe I have a bad spoiler, it was that way on 2 different trunks.
  5. Paul Masson
    1971 Grabber
    Mine doesn't line up that well, either. It's a good 1/4" out (too high) on the passeneger side for sure. My spoiler has been sitting like this since September... 1970! :biglaugh:
  6. predfan2001
    Yep that's about like mine. 1/4" or more too high on the left side. I even tried enlarging the holes some with a rat tail file. Didn't help.
  7. 71gold
    is it not fitting tight to the trunk lip on that side?
    I know with any tension on the lift spring, my lid would set higher on the left side.
  8. predfan2001
    The trunk is adjusted fine now, it's just the spoiler. I loosened it up and tried to move it down, then it didn't align with the qtr. extension. Maybe the spoiler is warped?? I'm going to adjust on it some more later.
  9. layne
    layne Member
    Orlando, Florida
    70 Maverick, 70 Mach 1, 70 Cougar Eliminator
    38.JPG Here is a picture of my trunk lid without the spoiler on.
  10. Craig Selvey
    These cars are Mavericks....not Mercedes-Benz. There will be some alignment issues. :D
  11. Dave B
    My brown car, had 8 holes in the trunk lid, from the factory...they musta been drunk.
  12. redfivexw
    redfivexw Member
    Thanks for the photos, those really helped, i cant wait to install my spoiler!!!
  13. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    No, that was the factory lightweight option. :D
  14. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    ALIGN IT AS GOOD AS YOU CAN GRIND A LITTLE ON THE TRUNK LID IF TOO HIGH AND A LITTLE USE OF FILLER WORKS WONDERS IT HELPS TO BE PART BLACKSMITH WHEN WORKING ON OLD CARS:rofl2:
  15. FL_Dave
    FL_Dave Member
    Apollo Beach, FL
    1977 Maverick
    I know this is an old thread, but I'm about to do this myself on a 1977. I also need to replace the side pieces, so any advise on those would be appreciated. The mold I bought actually has the wing piece on the bottom as part of the mold, but I also have those individually so it may be better top cut those molded ones off and use the real ones. Again, any advice is welcome.
