Lokar kick down w/Demon issue
Discussion in 'Technical' started by MaverickEsquire, Jun 8, 2016.
  1. MaverickEsquire
    MaverickEsquire Member
    NC
    1971 Maverick 2-Door
    Its maverick day....
    Lokar kickdown is rubbing my valve cover where it attaches to the carb. Carb is a Holley Street Demon (making the switch from an Edelbrock 1406).
    Anyone heard of this problem? Search didn't ping much. Where it is rubbing, I can only assume this is a common problem I just haven't heard of.
    Thinking of flipping the attaching stud to the inside and mounting the cable that way. Unless someone objects to that.
    Using a thicker spacer plate might also work if hood clearance isn't an issue...
  2. MaverickEsquire
    NC
    image.jpeg image.jpeg Picture of the rub. Picture of current clearance fender sideview
  3. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    I think carb space is a answer
    jasonwthompson likes this.
  4. MaverickEsquire
    NC
    Awesome, thanks! I'll order one.
    The 1" spacers from holley are cheaper than the 1/2" ones for some reason - so it looks like I'm going 1"
  5. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I think all you have to do is move the linkage to the inside of the throttle away from the valve cover. that is how it is set up on my holley.
  6. MaverickEsquire
    NC
    That was definitely my preferred method (super cheap). If you haven't had any problems that way I'll do that right now and cancel my spacer order
    Thanks for chiming in!
