lug nuts
Discussion in 'Wheels and Tires' started by Zooomzoomguy, Sep 4, 2006.
  1. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    ok i was thinking about purchasing the weld pro star wheels, summit p/n WLD-96-58208, which lug nuts would i need to buy for these wheels? part numbers would help alot :)
  2. Mavaholic
    Looks like the CLL-L5120 Would be the ones you want.
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    If you ever plan on running it at the track, you 'might' need open-ended nuts for the rear depending on what kind of day the Tech is having.
    I had to change mine out to open-ended on the rear. They allowed closed ended on front.
    I don't have an NHRA rule book handy, but I believe that is one of their rules.
    Can anyone else jump in to confirm?
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    yup.....if running slicks must have wheel studs......
    *Edited due to bad(wrong) information that Don made correct for me :bowdown:
  5. don graham
    nhra rule is that the diameter of the stud, say if it is 3/8 or 7/16, that length must go into the stud. doesn't have to go past it. my front ones don't go all the way through. :)
  6. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    thats what I said.......... :rolleyes:
    well, OK...thanks Don :clap:
  7. don graham
