manual transmission/clutch help!!!- probably a simple answer
Discussion in 'Technical' started by forrest34, Jul 25, 2018.
  1. forrest34
    forrest34 Member
    provo- orem, utah
    1974 maverick grabber
    I decided today to replace the bushing that keeps the clutch rod hole from getting stuff in the cab. (which mine was since it was gone). It should have taken five minutes but no...When I detached the clutch pedal assembly from the z bar the pressure piece that goes on the transmission fell off (fork rod into the itch fork- I guess) and now no matter what I do I am short an inch of space to get it back on.
    Help me, please. there is probably a trick to it, but in my 3 hours working on it I could not stumble upon it.
  2. baddad457
    Just from trying to recall working on my 67 Stang 30 something years ago, there's another return spring up inside the dash you have to work against. That's probably what's holding you up here.
