Maverick Goodies and Stock Amp question
Discussion in 'Audio' started by Stormin Norman, May 10, 2009.
  1. Stormin Norman
    Stormin Norman Member
    Winnipeg, Manitoba, Canada
    1979 Fairmont Squire
    Well, I've been looking for a part number for the AMP switch for the dash. The problem is the Amp comes from a 2-channel system out of a 1984 Mustang. The Premium Sound radio comes out of a 1984 Cougar. I've got the wiring diagram to install the 1984 into a 1978-to-1980 Fairmont. That's not the issue. The issue is that the 2-channel amp can be modified into a 4-channel amp, but the AMP switches appear to be different. The 1984 is an ON/OFF 2-wire switch. The 1979 is a block-buster beast, according to the 1979 to 1983 Fairmont/Zephyr manuals, but there's no picture or reference to the Switch numbers.
    All I want to know is if it needs a two-wire switch or the octopus switch from 1979. and what part number I should look for.
    It would start off with either D9F4-1XXXXX-XXX, E0F4-1XXXXX-XXX or E3F4 or E3F4-etcetera. The later ones, after 1986, went on with the radio switch.
    Now, don't raz me about upgrading to a new, improved upgrade. These radios go for $350 to $575, without the AMP! And they're used! For my little wagon, that's just fine. I like two knobs on my radios and... :evilsmile :rofl2:
    Now for the Maverick and other 1970 Ford goodies:
    http://www.perogie.com/index.html
    Unfortunately, the Maverick parts are here, under Other Parts (No respect) :biglaugh::
    http://www.perogie.com/other.htm
  2. Stormin Norman
    Got the Switch Part Number from my local Ford Dealer: D9ZZ-18B853-A. This is for 1979 to 1982 Farimonts and other Fox cars. From 1983 the switch changed to a 2-wire switch.
    So far, Haynes seem to have the best wiring diagrams in the Fairmont/Zephyr manual, showing the change in Premium Sound wiring and switch layout diagrams.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I had a 1980 Thunderbird with the Premium Sound System and the amp switch. Had a spare stereo and amp switch. Not sure if I still have it or not.
  4. Stormin Norman
    Do you remember if it had 2 wires or a big block of 8 from the Amp, 7 to the speakers and 5 from the radio? This switch is the one for my car - it amps up all four channels. The other just the 2 rear channels.
  5. maverick1970
    Missouri
    If I remember correctly it had way more than 2 wires.
  6. Stormin Norman
    Do you recall if is it a push/pull type like this?
  7. maverick1970
    Missouri
    Yes it was a push/pull amp switch, don't recall what the bezel looked like though. I had a complete setup, stereo, amp and switch.
    I will look around for it, probably won't be until the weekend though.
  8. Stormin Norman
    Outstanding! If you do find it, would you post a pic or PM me? Thanks! :thumbs2:
  9. Stormin Norman
    Oh! I was looking around for some extra wiring info and stumbled on this site, FULL of free schematic and wiring/car manuals from all over the world (a useful aspect of the internet and why we pay for the connections - payback :biglaugh:)
    http://www.ebooksquad.com/category/automotive/ford
    This links to Ford only documents (over 1000 at 10 per page (106), but most other brands are there too.
    Tip: Right click the article for a new page, then right click the blue download button on that page. It often takes you to the source site. Then clean-back the URL address and see if they have more files!
    I found a great Amp DIY on there too (circuits don't scare me - I was a Mech-Tech in the Army):
    http://www.ebooksquad.com/search/amplifier+circuit
  10. maverick1970
    Missouri
    Will do. PM me your email address.
  11. Stormin Norman
    Already sent.
