maverick grabber vin #
Discussion in 'General Maverick/Comet' started by tjwstang, Aug 3, 2005.
  1. tjwstang
    tjwstang Member
    lynnhaven fl
    1971 Maverick Grabber
    is 93 in the vin a grabber or is 91 in the vin a grabber ? any help appriciated tim:hmmm:
  2. Acornridgeman
    Wisconsin
    93 is the 3rd and 4th number of the VIN for a Grabber. 91 is the 2dr hardtop standard and 92 is the 4dr.
  3. tjwstang
    tjwstang Member
    lynnhaven fl
    thanks for the help im looking for a car a 1970 71 or 72 grabber 302 4 speed if yall see one for sell let me know 1000.00 to 8500.00
  4. MavMike
    MavMike Mile High Mav
    Denver, CO
    2 '70 Mavs, 1 '71 Mav, 1 '74 Grabber
  5. Jamie Miles
    Like said above, 93 in the VIN means it's a Grabber. Also, body code 62D means it's a Grabber
    Another way to tell is look under the passenger side about mid way under the door (where the arrow is pointing in the 2nd pic). On a real Grabber there will be 62 stamped there. Here's some pics:
  6. Acornridgeman
    Wisconsin
    Not exactly --- all 2 door Mavericks will have the 62 stamped into the rocker, both standard sedans and sport sedans (Grabber). Drivers side gets that stamping too. 62A was a standard 2dr and 62D was a Grabber 2dr. 54A is a 4 door.
  7. Jamie Miles
    Hmm... I'm pretty sure my '76 nor my '73 have anything stamped there. And I'm pretty sure I originally heard it on here that only grabbers had the stamp there. :hmmm:
    Ohh well. As always, it's very likey that I'm wrong. :rolleyes:
  8. tjwstang
    tjwstang Member
    lynnhaven fl
    thanks guys still looking tim
  9. Acornridgeman
    Wisconsin
    Might be another one of the many "some had it, and some don't" things about the Maverick. I just went out and looked. Both my 72 and my 76 parts cars have the 62 stamp on both the passenger and drivers side rockers. And they are both 62A standard 2 doors.
  10. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I have had 2 NOS rocker panels ... both were stamped 62 ... Never noticed if my 74 hasthem or not .. my Grabber definitely does ..
  11. dawnr
    dawnr New Member
    Sapulpa
    Hi, new here. I have a 1970 Maverick and trying to figure out if it is a Grabber. I am reading very conflicting and confusing info. It has 91 in the VIN, 62 with no letter under the door. What other things make the determination? Thanks for the help, pictures attached.
  12. Acornridgeman
    Wisconsin
    In 1970, the Grabber was an add on option package late in the run of the 1970 cars. They did not yet have their own VIN different from any other 2 door (62 body code).
    The hood with the little scoops was only used in 71-72, not 1970.
    Since it looks like your car has gone through many modifications over the years - the only real way you will know if it was born a grabber, is to get a Marti report.
    To see what was done to the stock 1970 to make it a grabber, check out Craig's web site. http://maverickcorral.homestead.com/grabberregistry.html
  13. RMiller
    RMiller My name is Rick
    Kennewick, WA
    The 62 under the door means nothing to the Grabber, I think it was an easy way to know if it was a rocker panel for the two door. In 70, the Grabber didn't have a specific identification in the VIN from what I have read but I could be wrong. 70 also did not have the Grabber hood, looks like all your sheet metal from the doors forward came from a donor car that was a Grabber. Does the car have a spoiler? I think the Grabber did have the spoiler but again, I could be wrong.
  14. winsteads
    winsteads Member
    TN
    1972 Maverick Grabber
    Grabber or Not?
    I just ran across a Canadian built late '72 Maverick (build date 07/72) and it has all the right stuff to be a real Grabber but the Body Code is a 62A and the VIN is 2X91F329484. Either someone went to a helluva a lot of pains to make a Grabber out of a standard 302 coupe or this thing is an oddball.
    Has anyone else ever run across one like this?
  15. Acornridgeman
    Wisconsin
    The 91 in the VIN is what tells you, it was not a factory Grabber. It would be 93 if it was a true Grabber. This applies to all Grabber models EXCEPT 1970 models. There was no VIN designation for 1970 cars.
    There are many Grabber "clones" out there. Since it was only cosmetic parts, it is easy to recreate one. The Grabber cars have nothing special in the design and build of the car. It is all bolt on parts, paint and decals.
    Craig Selvey likes this.
