max-power, I have good set of street heads that you could come and pick-up, saving shipping costs. I could meet you in Rochester. They are 68 heads with 58cc chambers, 1.94 intakes, 1.5 exhaust, screw in studs, hardened guide plates, dual springs and associated retainers/keepers, will fit 302 and 351 (drilled for 351) and the exhaust ports have been lightly ported (thermacter smog "bumps" removed). Used for one summer. You should be able to clean them up, repaint them and go. I don't see any defects but there is no gaurantee, so keep that in mind if you are interested. 320.00 for the set! I know I posted these in the past but I can't remember if it was you!
Yep, we talked about heads. I have a set of 70 heads that only need a little work, I think. I already ported them on the exhaust side, and all I need is hardened seats and a touch up grind. I will be sending them to the shop to have them checked in about a month, and if the work required costs much more, I will print this thread and get hold of you. As of right now, I don't think I need them. Thanks!
