Mystery Front suspension setup
Discussion in 'Technical' started by Workinonit70, May 2, 2017.
  1. Workinonit70
    Workinonit70 New Member
    Ri
    1970 ford maverick 302 t5
    Looking for some info on this setup on my 1970 Maverick 302 t5. Cant find any info on it. It has a odd square tubing lower arm and adjustable coilover strut. Aftermarket spindle with newer 99 gt mustang calipers. The steering arm bolts through the spindle and uses the caliper bolts. Very odd setup. I'm having issues with an alignment and the coilovers binding. looking for some info. Thanks!
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Interesting setup, almost looks home built. It looks like SN95 spindles that they cut off the steering arm and made new to work with the rear steer. You aren't any closer to an answer but it will move your post to the top!
