Hi all, I need the tool that is used to take the pins out of the turn signal connector, at the base of the column. If anyone has one, I would like to either buy it or use it, and pay shipping back and forth. I can't see $50 bucks at AK for this tool. Thanks in advance, Earl
pin removal tool Does your connector have the red piece in the middle? Both the male and female side has it. If it does you can take it out and maneuver the pins out with out a tool. If not, I generally find my pin removers at radio shack. There are even some plastic ones available for cheap. I may have on at the shop for that size. Aren't they about 1/8 inch pins? I assume you are trying to remove the male side.
Steve; thanks for the info. I will take a look and see about the red insert. I am sure it has it, at least the one from the donor car does. All I really need is the connector, as the wiring is good. I will let you know. Earl
