off topic i know,but
Discussion in 'Other Automotive Tech & Talk' started by mcmavv, Jul 20, 2011.
  1. mcmavv
    mcmavv Member
    ontario,canada
    76 mav
    ive got a prob with id ing an fe motor,aint got the talent or the tools to check the stroke accurately.what i need to know is how can i find out if its a 360 or a 390 like the breather says.cant trace the truck as it came to me with no paperwork and the cab is off of a 78.any help would be appreciated.
  2. grabberguy16
    grabberguy16 Member
    Courtenay, BC, Canada
    72' 2dr Maverick,70' 2dr Maverick
    casting numbers in the block should telling you I would think didnt that with my 302 to find out the year and it came in engine size and year and a few other things in google
  3. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    FE 's are hard to tell forshure without taking the bore/ stroke. There is a date code above the starter. Some later blocks have a partial VIN stamped above the bellhousing, don't know if it includes the 5th digit engine code.
    But I DO know that if it has "SUPER" stamped on a machined pad on the bottom of the block, its JUNK, and should be sent dierctly to me for propper disposal (y)
  4. mcmavv
    mcmavv Member
    ontario,canada
    76 mav
    thing is
    engine is still in the truck making finding #'s a bit tough.it is a auto 4x4 so its worth looking in to.runs ex.even with a real crappy 2bbl and points ign.
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Probably wont know for sure unless you check stroke or drop the oil pan and check the stamp. It really dosnt matter as everything is interchangable and both seem underpowered with a 2 barrel carb to me.
  6. mcmavv
    mcmavv Member
    ontario,canada
    76 mav
    and if by some freak of luck,
    it says super there what exactly is it.cant get near pullin the pan right now,gotta move alot stuff before winter hits,and i mean alota stuff.
  7. simple man
    simple man Member
    Bunnell,Florida
    Here's an easy way to tell. Take out any spark plug that is easy to get to. You will need a friend to help. Get a small rod ( a 22cal cleaning rod works great ). Have your friend turn the engine while you hold the rod parallel to the piston through the plug hole. when it gets all the way to the bottom have him stop and you make a mark to some reference on the head. Turn the engine until the rod is at the top of the stroke and measure the length from the same reference point. A 360 will be 3½" and the 390 will be 3¾"!:)
